TDA7297 output
No. You can parallel the inputs, but you need to add say 0.22R series
resistors to all 4 outputs before combining them to 2 terminal mono.
Well that is the theory, but in practice it is hard to say if they are
really needed, I suspect due to internal chip details not given in
the datasheet, perhaps not. But better safe than sorry.
The small resistors are needed to absorb any small voltage
DC offsets and AC gain differences between the two amplifiers.
Those sort of resistances may already be in the chip.
IMO they probably are, but I'm not guaranteeing anything.
rgds, sreten.
It's been done, paralleled (no resistors). It may not be as accurate. They're cheapish, so trying two chips might be a nice idea, and not paralleling.
The amplifier is in balanced mode internally so you can't bridge it or connect - output to PG.
