But I'm not strictly high efficiency because of solar charging and for environmental reasons but because energy efficiency is the only way our civilization can have a future. Using 4-5 (or in the case off class A amp 100) times more energy than is needed is a wasteful practice that should be eliminated where ever possible. And what better way to start than by the things you use in your own home.
Well, I wonder how much energy your computer uses compared to a TDA7297? I know my laptop needs a fan, yet my little 7297 can provide all day serious listening levels while remaining at room temperature.
I leave the 7297 on 24/7 and it has the advantage of not emitting FM polluting RFI.
Cheap inefficient speakers are what draws the juice, mine draw only .085wrms each. Anyway, we use Hydroelectric power up here in friendly Quebec.
I wasn't sure where to post this and hope I haven't broken any rules regarding posting in 2 forums.
I've built a new stereo comprising a TDA7297 amp and a 12AU7 Valve Cmoy Headphone for preamp. The speakers are a pair of foam core Karlsonators with TB W3-881SJF drivers.
It is really quite remarkable how remarkable this little little set-up sounds.
It was great fun to build- hope you enjoy it 😀
cheers
Just ran into this thread!, I have a TDA7297 amp and have W3-881SJF speakers looking for a cabinet.
I have modded the amp per excellent guide here: TDA7297 Build Guide and I am very interested in building Karlsonator, where can I get detailed information for the speakers?
Here:
http://www.diyaudio.com/forums/full-range/239338-mini-karlsonator-0-53x-dual-tc9fds.html
My latest driver is the 3FE25. Sounds awesome and has 91dB sensitivity for $19 ea.
Hello! My first post in this forum, I wonder if the 7297 will get to hot to be built in to one karlsonator? And if it is possible to build it in to the speaker box where would it be best to place it?
Thanks for a great forum and great advice. I am now planning to build a pair of Karlsonator for the kitchen and office to match my Carlssons in the living room. Sonab OA-12 - CarlssonPlanet
If you run the 7297 with 12v supply or it is fine and can sit inside Karlsonator. Anywhere inside near bottom and towards back panel is fine. I tried running it with 19v supply and it gets very hot. Too hot to touch - not recommended.
