Hello,
Stereo audio IC TDA2615 datasheet indicates +/-Vp: 21V as a maximum supply voltage range, does it mean that it's between + and - in a symmetrical supply or each voltage rail can accept 21V max, referenced to ground?
TDA2615 pdf, TDA2615 description, TDA2615 datasheets, TDA2615 view ::: ALLDATASHEET :::
Thank you for your help,
Manuel
Manuel
6 W is pretty low for a ±12 V supply, so it's not the most efficient chip in the world.
Note that while the ABS MAX is ±21 V, the chip is actually spec'ed at ±12 V. I would take that as a clue that ±12 V is the optimum point. I would imagine that the chip would be limited by its ability to get rid of heat above ±12 V.
Just some things to keep in mind. It looks like a chip that's easy to use otherwise, though.
Tom
Tom
Yes, i have a 12V symmetrical supply.
I'm using chips that are taken from old CRT TV, and it's intended to drive two full range 15 Watt loudspeaker, i believe 6 Watt is more that enough.
Thank you for your feedback.
Yes, +21VDC and -21VDC maximum for the bipolar supplies.
Thank you
