Hi All,
I’m playing with an i2s source with only 3 wires. B clock, Word clock and Data. On my TDA1543 DAC with i2s input, I see 2 GND lines. I just ignored them.
There’s no music coming out. I can only hear shhhhhh noise. Any ideas ?
Thanks in advance.
Eric
Thanks in advance.
Eric
There is no such thing as a voltage. You have also just discovered that there is no current without a circuit. Mr. Kirchoff had something to say about these two issues.
It worked. Thanks, Abraxalito. I hooked the TDA1543 DAC to an Airplay receiver. Sounds awesome. This is my first foray into zero sampling DACs.
This DAC replaced my Arcam AirDAC. The Arcam is too clean sounding, treble over-resolution (if there's such a thing)
The TDA1543 is fairly sensitive to its power supply quality. You can improve the SQ with more caps on the supply if you're up for tweaking.
- Digital Line Level
- TDA1543 and shhhhh noise
