tda1541a tubedac question
dhaen.
basically I am building a dac according to the schematics further up.
Klaus says on his site that the values on the schematics are adjusted for usage without the amplimo 1:15.
Since im going to use the 1:15 and the 75mH inductors. i need to know what components that should be changed in valueso i can use the transformer.
Anyone who even built this one?`
/kasra
I'm building something similar, but with two TDA1541. Look at an earlier post 2*TDA1541.
I am using the TM3, but i don't have any additional filtering (yet?).
Can't say i hear a difference when i compare with a normal player (freq response that is, not overall performance!).
But the filtering is probably more for keeping high freq away from the next stage and not so much filtering in the audible range (?)
Going to do a proper listening tonight with a friend and a well known set. See you the DAC performs.
Greetings,
GuidoB
