I just got some of these in the mail. Does anybody know how these differ from plain vanilla TDA1541A ??
Their somewhat better in specs but not as good as S1/S2. IIRC they were meant for the Japanese market.
HeadSh0T said:I just got some of these in the mail. Does anybody know how these differ from plain vanilla TDA1541A ??
Hi Headshot,
Go to:
http://www.semiconductors.philips.com/
Then search for TDA1541
Then click on DIGITAL (second line of found items)
The PDF-file contains specs of all versions of the TDA1541.
A or R1 is the lowest grade.
Hope this helps.😉
I am correct. They are 1 dB better in THD+N at -60 dB. Just like I said: somewhat better than the normal TDA1541A.
Again
In degrading order:
TDA1541A-S2
TDA1541A-S1
TDA1541A
TDA1541A-R1
TDA1541
The gap from any A version to the TDA1541 is quite big; differences between the A versions are minor
FYI;
S stands for Selected specs
R stands for Relaxed specs
In degrading order:
TDA1541A-S2
TDA1541A-S1
TDA1541A
TDA1541A-R1
TDA1541
FYI;
Rudolf, please see:
http://www.semiconductors.philips.com/acrobat/various/DIGITAL.pdf See page 17.
In degrading order :
TDA1541A-S2
TDA1541A-S1
TDA1541A-R1
TDA1541A
TDA1541
R1 specs are slightly better than A-only according to Philips and I think they should know what they produce(d).
I used to have a Sony cdplayer which had a TDA1541A-N5. Never found info on that one.
TDA1541A-S2
TDA1541A-S1
TDA1541A-R1
TDA1541A
TDA1541
What about Tda1541a with S1 but without the crown? I believe mine is a remarked Tda1541a. What i mean is fake Tda1541a-S1.
What i saw on the net is that all Tda1541a-S1 is with a crown on it but not mine. Some body might have remark this i guess.
Anybody have the same tda1541a like mine?
this is what's written on the DIP package...
"TDA1541 R1"
no "A"...
there's no Philips logo either...
weird..
"TDA1541 R1"
no "A"...
weird..
Just reread what you wrote and I mistakenly read TDA1541A-R1. Probably because you asked what the differences are with plain vanilla TDA1541A. The R1 of the latter is slightly better and the best are S1 and the very rare S2. I gave up hope finding a S2. Seems like Mr. Zanden has them all 😉
I did not even know of TDA1541 R1, but since it's without the A it is practically useless. TDA1541A is a "bugfixed" version of the chip because there were problems with TDA1541. TDA1541A sounds a lot better too.
You should know that these TDA1541 only work with SAA7220PA.
TDA1541A only works with SAA7220PB.
This counts only if you want to use them in a cdplayer with 4 x Fs.
The rebadging of these chips is new to me but some people do anything to make money. Real TDA1541A-S1 are branded with the Philips logo on the left, a crown right-under and S1 on the right upper side. Mine are coded with TDA1541A, in the second line: 11113 and in the third line HSH8910 2. The printing of S1 and the crown are in a slightly different white. There is no text underneath the chip.
TDA1541A vs TDA1541A-R1
jean-paul said:Rudolf, please see:
TDA1541A-S2
TDA1541A-S1
TDA1541A-R1
TDA1541A
TDA1541
This note is found in the TDA1541A product specifications:
Selections have been made with respect to the max. diff. linearity error:
TDA1541A bit 1-16 Edl < 1 LSB
TDA1541A-R1 bit 1-16 Edl < 2 LSB
TDA1541-S1 bit 1-7 Edl < 0.5 LSB
bit 8-15 Edl < 1.0 LSB
bit 16 Edl < 0.75
I wonder why the R1 is better than the plain A version for THD+N?
schnitzer
Correction to my previous post..........................................
For the TDA1541 versions listed by selection criteria, the TDA1541-S1 shown should be TDA-1541A -S1
thanks jean paul
hmm.. thanks for the info on the TDA1541. I guess that's why they were cheap.. only 4euros!!!
oh well. it was too good to be true..
This is nonsense 😱
TDA1541A versions will work on either SAA7220A or B
TDA1541 version needs pin 4 to be connected (internal reclocker).
It really depends on implementation of a cd player if pin 4 of TDA1541(A) is connected to BCK for example or not.
I've stated this all before in previous posts, I won't bother anymore.
It's funny seeing how some keep persisting and developing these myths and misconceptions.
The biggest improvement to any TDA1541 is removing that opamp based I/V and adding DEM reclocking.
IMHO it sounds better than the TDA1543 WITH resistors as I/V.
rbroer said:
This is nonsense 😱
If you say so I believe it, Rudolf. The information I have was told to me by various people that used TDA1541/A long before the hype. Even the people I bought my TDA's from gave the same info. This includes info from known audio people. It has become a self-fulfilling prophecy this way.
So I guess it is again not wise to believe everything people say. Recently I heard again from a DIYer that in his cdplayer TDA1541A did not want to cooperate with SAA7220PA. Your explanation about pin 4 says it all. Nevertheless documentation is scarce about TDA1541/A + SAA7220PA/PB, maybe that is one of the reasons that myths and misconceptions are created 😕
I am very sorry I too kept persisting this myth especially since I like facts not fiction. Hopefully I am not one of the
That it sounds better than TDA1543 is a real fact I experienced myself various times, just like A-S1 sounds better than A-only. Till now I only used the A or A-S1 version for DIY and if I see an examples of TDA1541/SAA7220PA in a device I always replace them for the better combo from my slowly but steady diminishing stock. Differences between either A versions and TDA1541 are quite big as you stated too.
rbroer said:
This is nonsense 😱
I've stated this all before in previous posts, I won't bother anymore.![]()
Hi, can you please tell me which opamp to remove and where to find it? What is DEM reclocking and how do I do this?
I am new to all this, having purchase a Marantz CD273 with 1541 chip in it. It has 2 LM833N opamp. Thanks.
Hello gentemen,
What does "max. diff. linearity error" stand for?
As an R1 owner I wonder what's the better THD specs vs the LSB story.
Grading process of the Philips TDA1541A into R1 and S1 grades. - Marantzphilips.nl
But most important, do a R1 sounds clearly not as good than a plain A?
Matthieu
Matthieu
- Digital Line Level
- Tda1541 R1??
