Hy there !
I hate to start a new thread but I would need some help
about TDA1541 DAC.
I've decide to build a simple non-os no reclocked DAC with
a chip I could see without a microskope...and I 've found
one on Fedde site - the NONOZ DAC with TDA1543.Simple and beautifull and apparently good sounding.
But here is my problem:
-The local store where I suppose to buy TDA1543 don't have
them anymore...they only have TDA1541 and TDA1541A.
Is there a simple non-os DAC schematic with TDA1541(A)...I mean
without reclocking.I found only the reclocked non-os version of
TDA1541 DAC ?
-The other problem is the receiver CS8412 - I can't find it...
at least in the stores around here.
Are there any other receivers (containing quartz if possible),I could use it with TDA1541 ?
Any help would be highly appreciated.
Regards;
Igla
about TDA1541 DAC.
TDA1541 DAC ?
Regards;
Igla
Here's a well done DAC, non os and without reclocking
the 8412 may be hard to find and expensive (approx 15€), if you want use the 8414, mostly the same in smd format
http://thunderstoneaudio.nav.to/
Thanks a lot Bricolo;this is exactly the schematics I
would like to implement...simple non-os DAC without reclocking.
I went for TDA1541 just because they are on stock in my local store and TDA1543 is out of stock.Othervise I would rather
try the NONOZ DAC.
The problem is still CS8412 or CS8414.I can't get them arround
here and I think I will be forced to use crystal and some other
receiver more easy to find.
Any suggestions which "easy to find " receiver and cryistal
to use ?
Regards;
Igla
try the NONOZ DAC.
to use ?
Regards;
Igla
