Are the TDA1541A dac chips on ebay real ?
Can someone recomend a seller that has supplied a geniune deal, or if the majority is geniune, I guess post who to avoid.
Thanks.
Srinath.
Thanks.
Srinath.
very difficult
can you post picture of your TDA
As lordearl says, it is not the chips that are faked, that is probably impossible and still function. The fakes you have to worry about are the premium grades, e.g. double crown or s1, etc, as it is very easy to take a standard grade and add the crowns or the s1 grade symbols. If you get a standard grade tda1541a from a seller with good feedback it will almost certainly be legit. Probably cost between $15 & $20. If you go for a $90 double crown it is probably a standard with some silk screening.
Like this one
TDA1541 SAA7220 CS8412 Fiber Coax USB DAC Kit WLX | eBay
I was just looking to buy somehting like this one for example -
And an unrelated question -
Does TDA 1543 based DAC Kit's sound good ? Its a easier kit to build - It has fewer power inputs needed.
Thanks.
Srinath.
Thanks.
Srinath.
- Digital Source
- TDA1541 DAC chips on ebay fake or geniune
