TB W5-1611SA vs. MA Alpair7
Well if I go with the initial 30cm diameter, the internal volume should be 18.99L , driver volume still to deduct (anybody has an idea how much is that?). The back end opening (if port is needed) will be 50mm. As soon as I start fabricating the enclosure, I start a step by step build thread, if anybody wishes to XEROX (read copy 🙂 ) it. I don't mind...the more the better....
Danny
