After looking over many full range drivers in the 4" range, these look pretty good for a BIB build. 61" x 11" x 8" though I'd probably just shorten it to 60" high.
Tang Band W4-1879 4" Full Range Driver | Parts-Express.com
The BIB config should get the most out of this bass capable driver. It is 8 ohms with an SPL of 87 db which is better than many of the current crop of 4 inch full rangers. My soon to be completed Tubelab simple se might just drive them nicely too.
I could use an "easy" project these days and a BIB is about as easy as it gets!
>>> though I'd probably just shorten it to 60" high...
What!?! You may ruin everything by doing that!
Just kidding. It shouldn't make any difference at all. You won't get any arguments from me about using that driver in a BIB! If it's anything like one of it's big brothers, W8-1808, it will do the 'tone' thing extremely well and be a very enjoyable speaker to listen to for hours. Please keep us posted if you build this.
Zilla
Zilla
I had was supposed to be sent the last one they have instock, but it was put on back order for some reason. I do however have the 3 inch version (not much cone area left after you take out the surround and phase plug).
Interested to hear someone's feedback on these drivers... Do it and tell us how it goes!
Our youngest decided he wanted a violin for Christmas so the budget is a bit tight right now. Thought about building a single woofer in an h frame with the goldwood 18" since my pre has a sub output. Probably would be a good fit with my coniston^2's if I picked the right plate amp.
But getting back to the TB 1879, this seems to be a no brainer choice for a BIB build, particularly for a newb to DIY speaker building. Somebody ought to do it......
Our youngest decided he wanted a violin for Christmas so the budget is a bit tight right now. Thought about building a single woofer in an h frame with the goldwood 18"...
Hmmm... a good idea, I'll have to keep it in mind for when my boy gets a little older. Even still, I doubt I could get away with gifting a driver rather than a violin...
- Full Range
- TB W4 1879 in a BIB
