TAS5630 amplifier issues
Hi
I have three of these TAS5630 (G300V33BTL, beware of the small internal fan, very noisy) amplifiers from SINEWAVE and when I feed stereo audio to them from my Macbook, one speaker has normal volume but the other speaker has about 10% of normal volume, balance is set properly, speakers are Jamo A10S (6ohm, 86dB).
Plugging only one speaker in to either channel works fine, both together then you can only hear the quiet channel if you put it up to your ear.
Any ideas what is causing this, I can get proper single channel output on either speaker, so it doesn't seem to be the speakers or cables?
All three amplifiers exhibit the same problem, I can only think that it might be a fault in their design that causes incompatibilities with certain speakers?
Thanks for looking.
Best regards
Richard
