TAS5611A
removed
That looks very fancy, how does it sound?
I assume that money is no object here, but is a 4 layer board and those pretty crazy looking Jensen caps at all necessary?
Is the copper pour on the top/bottom side grounded too? It probably isn't a good idea to leave it floating.
Almost rdy for sound. Need a few holes made on my enclosure.
I prefer 4 layer boards. 1st attempt using 4 pole capacitors. Looking forward to the results. I designed this amp for my 98db 4-ohm speakers.
The pours are connect to ground with a ferrite bead in a couple places around the board.
Included a pic with the output filter caps.
Dwight
Yes, 4 layers are nice if you don't mind the extra cost.
IMO, I would stitch the pours right through to the main internal ground plane. Connecting the outer planes with ferrite beads in only a couple of places could lead to ground loops.
Still, looks great. Nice use of board space with the components on both sides.
