Targa TG -18D (MA Audio HK2000d)
remove the outputs and if there is still more than a tiny fraction of a volt across the speaker terminals, connect a load to pull the voltage as close to 0v as possible.
Do the drive signals return?
To have drive out of the LM319, the voltage on pin 4 must fall between the top and bottom of the triangle waveform on pin 5. Having DC across the speaker terminals is likely what caused the offset on pin 4 of the 319.
