Taramps power supply
Hey guys got a taramps MD8000 1 ohm model here that has a smoked power supply (output is fine)
I can see it's blown the buffer chips. But I can not read what the part number.
Suspect IC is 'IC3'. The other side of the board seems in better condition but I can not find any other chip with the same numbers as I can make out on the burned IC.
Here are a couple of photos.
One of the burned chip and 1 of the other ICs that are similar.
Cheers guys
Have you tried contacting Taramps themself. The guys there are very helpful I had a problem with a HD8k and they also went through the fault with me as well as wanting to put me on the data base so I could buy spares direct from them. The only problem was the exchange rate from USD to ZAR.
