Taramps MD8000.1 2ohm model. Output help
i just received a md8000.1 model that appears to have shorted some diodes in the output section.
Are these 15v 1watt zenner diodes?
I would pull them out of circuit and check them. I have found that many times something they are connected to is shorted and not the diode itself.
I just look at a schematic I have on hand for a similar amp and it shows 15v 1w diodes.
