Tapped Horn - From Parts On Hand
I have been reading a lot of the threads on tapped horns and I would like to try to build one. I found a design by Don Snyder that looked like it may meet my needs.
One change I would like to make to the design is to move the opening from the side (c in the first drawing) to the bottom (f in the second drawing). I don't believe that this should be a problem.
I would also like to use one of the Shiva 12" drivers that I have on hand. I took the Hornresp parameters supplied by Don and hopefully updated the information for the Shiva driver correctly.
I am primarily looking for bass extension to the low 30Hz range. I believe that this design gives me 30Hz - 80Hz ±3dB.
I would appreciate any comments or suggestions. I would especially like to hear if I have missed something.
Cheers, Bryce.
Moving the mouth should be okay - doesn't look like the path lengths change much at all, so you're likely to get away with it.
Might be worth double-checking what happens if you enable Lossy Le on Hornresp - drivers with lots of Xmax and high inductance are often more accurately simulated with Lossy Le (or semi-inductance, if you've got the additional data) in place.
Chris
Another 12" Driver
That response curve suggests that particular driver does not really want to be mounted in a TH.
Hi Brian,
I have seen the first 12" driver used and the results are reported to be good. Is this speaker also not the best choice for a TH? The graph looks very similar to the Shiva graph to me, but I am not sure what difference I am looking for.
The second image is the Beyma 12LX60. Am I correct that this driver is a better fit for a TH?
Thanks for your help.
