Today I can't connect thru tapatalk and last update was 5 days ago. Web works OK.
edit: more info
edit: more info
I am experiencing the same problem with tapatalk as miksi. Same error message when password is entered. Web access by PC is fine. No tapatalk 🙁
I also can't access via TapaTalk. According to TapaTalk's support forum:
The [TapaTalk] plugin for [diyAudio] is old and may not communicate reliably with the latest versions of [the TapaTalk app].
Please notify the owner [of diyAudio] to update the plugin?
Same here, when I try it says "get_config network error try again later"
Yep same here. It sucks because I use Tapatalk pretty heavily for reading here.
Tapatalk still not accessing diyAudio as I reported above, however the error has now changed to "get_config network error try again later" as indicated by riven67.
Glad to see I'm not the only one having TapTalk issues. I get a message "failed to connect to server. "
Android TapTalk Pro 4.6.2
The guys at Talkbass ditched Tapatalk recently due to te amount of time it was talking to support after recent "updates" I must admit I found that a problem but the people that run theses fora are usually volunteers so maybe we have to bow to their decisions,
Having the same problem here too. I'm not 100% happy with the app anyways. If it doesn't get fixed soon its not the end of the world, Ill just stop using it.
There is no Android alternative that I can find. Without Tapatalk you're down to reading via a web browser on your portable device, and this board doesn't seem to have a format optimised for mobile via the browser. So Tapatalk is it. Lets hope it can be fixed asap.
- Site
- Forum Problems & Feedback
- Tapatalk problems
