A pair of professional passive studio monitors (or great home stereo speakers 🙂) with one of the most regarded 20 cm (8") coaxial drivers (Tannoy 2062).
They are known for the very light paper cone and the tulip high-frequency driver concentrically mounted onto them - time aligned.
Excellent condition with minor signs of wear on the boxes.
Basic specifications:
Will be shipped securely.
Contact me here or by email: veselin.karavelov@gmail.com
- Frequency response: +/- 3dB 85Hz - 22kHz
- Recommended Amplifier Power: 150 - 260 watt / 8 ohm
- Power Handling Average: Programme Peak (10ms) 130 watt 260 watt 520 watt
- Sensitivity: 95 dB (half space) / 92 dB - 2.83 volt @ 1m
- Impedance: Nominal: 8.0 ohm / Minimum: 6.4 ohm
- Dimensions: 388mm(H) x 280mm(W) x 280mm(D)
- Weight: 8.2 Kg
