I was just given a pair of Tannoy 607 SIXES by a neighbor who on the verge of trashing them. they are in good condition in original box.
Does anyone know the specs for the elements in them, or have ideas for other use of the elements?
Bump!
I am thinking of using the elements from a pair of Tannoy 607 Sixes for something fun.
transmission line, TQWT, omnipolar etc. any suggestions?
Drive units 25 mm aluminium dome tweeter
8" bass unit
Recommended amplifier power/channel 10 - 100 watts
Peak power/channel 175 watts
Nominal impedance 8 ohm (minimum 6 ohm)
Sensitivity (2.83 V @ 1 mtr)88 dB
Frequency response +/- 3dB 50Hz-30kHz
Crossover frequency 3 kHz
Crossover type 1st order low pass
1st order high pass
Terminals Bi-wired
System type ducted port
Internal volume 17.0 litre
I have not found any further secs on the elements.
8" bass unit
1st order high pass
Terminals Bi-wired
