The TSP parameters:
Tannoy System 800 (or CMS8) driver specifications
Tannoy 2046 8" Dual Concentric:
Znom: 8.000ohms
Revc: 4.400ohms
Sd: 196 cm^2
BL: 7.5253
Vas: 34.7
Cms: 635.4423 um/N
Mms: 23.2575g
Mmd: 21.6785g
Fi: 40.062Hz
Fo: 41.400Hz
Qms: 10.550
Qes: 0.470
Qts: 0.450
Pmax: 100W
Hvc: 10mm
Hag: 5mm
Xmax: 2.5mm
Cmx: 2.5mm
Cmo: 1mm
No: 0.51%
SPLo: 89.08dB
SPL 2.83V/m: 91.10
And the crossover for Tannoy System 800 (which uses this driver).
I have a schematic for the Tannoy System 800A too, if you want an active speaker.
Znom: 8.000ohms
Revc: 4.400ohms
Sd: 196 cm^2
BL: 7.5253
Vas: 34.7
Cms: 635.4423 um/N
Mms: 23.2575g
Mmd: 21.6785g
Fi: 40.062Hz
Fo: 41.400Hz
Qms: 10.550
Qes: 0.470
Qts: 0.450
Pmax: 100W
Hvc: 10mm
Hag: 5mm
Xmax: 2.5mm
Cmx: 2.5mm
Cmo: 1mm
No: 0.51%
SPLo: 89.08dB
SPL 2.83V/m: 91.10
Tannoy 2046 8" Dual Concentric - Measurements
Did you measure the response of these dual concentric drivers with that crossover?
If you have them could you post those as well.
Thanks!
DonM
Thanks!
DonM
DonM
No I don´t have any meaningful measurements (yet), I have to buy a measurement mic first.
But the crossover is the original one from Tannoy in my (factory made) System 800 speakers.
Here is the user manual (with measurements):
http://www.tannoy.com/products/160/uman_System800.pdf
Perhaps you could consider some simple Bass Reflex enclosures ?
Often Horns result in a thinner bass than a simple ported box... Unless of gargantua size.. Sad, but also true.
Yes, the Tannoy System 800 is a bassreflex with 21l tuned to 40 Hz. The active version
(System 800A) uses the same enclosure with some bass boost that extends the bass to
44 Hz (-3 dB). Manual:
http://www.tannoy.com/products/161/uman_System800A.pdf
I have a pair of the above drivers and would like to make a pair of horns in the style of Cain & Cain for a large room.
I have the woodwork skills to follow through with this plan but need help getting the T & S or pre-designed plans.
Please help.
FTI
Hi, I'm pretty new here. Newer than this thread actually..
I just read this and I think there might be some kind of misunderstanding. There are at least 2 different tannoy 8'' PP drivers: 2064 and 2046. They are similar but not the same. I have a pair of Tannoy System800 which uses the 2046 driver. I also bought some tannoy S8iw wall speakers with the 2064 driver. Not sure whether this:
http://www.speakerbits.com/index.php?page=shop.product_details&flypage=child_special.tpl&product_id=424&category_id=1208&option=com_virtuemart[/URL]
... is the right one(2064S). Anyway there is a pdf including TSPs and specs.
I tried and put the 2064 in the System 800 cabinet including System 800 crossover and it worked nicely together with an original System 800 (2046) in stereo setting, but I think the 2064 has less low end in that box. So I am not sure whether you can use the 2046 TSP for 2064.
Soon I will built up a speaker measuring system and hope to be able to measure both drivers.
Thanks to gk7 for the schematics!
Hope this is still useful
regards
matt
I am interested in the schematic for the 800A.The TSP parameters:
Znom: 8.000ohms
Revc: 4.400ohms
Sd: 196 cm^2
BL: 7.5253
Vas: 34.7
Cms: 635.4423 um/N
Mms: 23.2575g
Mmd: 21.6785g
Fi: 40.062Hz
Fo: 41.400Hz
Qms: 10.550
Qes: 0.470
Qts: 0.450
Pmax: 100W
Hvc: 10mm
Hag: 5mm
Xmax: 2.5mm
Cmx: 2.5mm
Cmo: 1mm
No: 0.51%
SPLo: 89.08dB
SPL 2.83V/m: 91.10
Schematic is attached to post 6 (from gk7)
- Tannoy 2064 8" and back horns
