As shown here: https://www.diyaudio.com/community/threads/tanka-se-and-balanced-preamps-presentation.428346/
Tanka SE and Tanka kits
Both kits are comprised:
WHAT YOU DON'T GET IN KIT:
- small screws, nuts and washers; you're Diyer, having them all
- Cinemag/Jensen/Edcor repeater xformers; it doesn't matter where you live, it matters where I live; if you're in Europe, take them from Don Audio... if not, take them directly from manuacturer - either way is cheaper than Mighty ZM importing them, then sending them abroad.
- Tubes; in general, each Tube Aficionado is passionate about his Toobz, so best to use what you have stashed; though, if you insist, I can manage Russkie (6J9P/6Ж9П for SE and 6N23P/6Н23П for Balanced) and I'm expecting their cost in range of 20E/pair; tested in Tube tester but also in my own preamp ..... best way to know they're perfect
Kit prices (all in Euro - €)............. first take a look at available pictures and graphical files, then on list, and just then look at numbers
SE Kit - 850€
Bal kit - 950€
That includes shipping wherever you live, but not Paypal fee; if Paypal fee (around 30€) is too much for your stomack, possible payment to my Biz Bank Account, usually it costs less.
Shipping time frame mostly dependant of custom Donuts production; they usually deliver in two weeks time.... so there it is.
Finished preamp prices (Modushop 2U/350 case, Neutrik connectors, front black or silver, mains voltage according to your needs):
-SE - 2350€
-Bal - 2450€
........plus legal export/shipping worldwide (100€ is covering that); Shipping goes through "Post Export" service, declared value of 500€, to save you of bigger Custom expenses
- Motherboard with all SMD work done
- TFT display/logic module fully assembled
- small pcb for SSRelay/connection of mains Donut's primaries
- Fancy remote (CR2032 battery you need to buy, can't send battery in package)
- assembled flat cables
- pcb IDC connectors
- encoder assembled (pcb, cable)
- protection perspex screen for display
- all necessary CAD files for front and back plate, sent by e-mail ...... Modushop already did several Iron Pumpkin cases, practically same job
- pack of schematic and graphic files, also sent by e-mail
- all resistors (metal film 0207 size), including NTCs
- all solid caps
- all electrolytic caps
- all heatsinks (in case of balanced, two additional custom Al plates serving as big hsnks; compromise, but best one)
- all necessary isolators ( mica, plastic bushings)
- all diodes and diode bridges
- all active parts - semis, ICs
- tube sockets
- jumper pins and jumpers
- all Fujitsu micro relays
- 30VA mains Logic/Heating Donut, custom made; static shield, magnetic shield, primary for your neck of Wood; regular fixing hardware included
- 30VA mains LoVoltage Donut, custom made; static shield, magnetic shield, separate secondaries for each channel, primary for your neck of Wood; regular fixing hardware included
- 20VA mains HiVoltage Donut, custom made; static shield, magnetic shield, separate secondaries for each channel, primary for your neck of Wood; regular fixing hardware included
SE Kit - 850€
Bal kit - 950€
-SE - 2350€
-Bal - 2450€
