What kind of mods, such as dampening certain areas of the driver and whatnot are out there to help increase the performance and sound quality of the TangBand W3-871S?
Also, I have heard these drivers often require a notch filter. What exactly is the best notch filter for this driver and what values should I use. Also, what ratings are required for the parts, i.e. 5 watt for resistors, or 21 gauge air core inductors....
thanks!
thanks!
For speaker mods, you could look at:
http://madspeaker.com/
Mark has some documented mods to the W3-881S
As for a notch, it would be speaker dependent.
Here is one example with the W3-871S
http://www.zaphaudio.com/archives.html
http://www.vikash.info/audio/W3-871S/index.asp
Good luck,
Gio.
Good luck,
Gio.
Relax said:What kind of mods, such as dampening certain areas of the driver and whatnot are out there to help increase the performance and sound quality of the TangBand W3-871S?
thanks!
