Tang Band W3-1878
I would like to know your opinion about the speaker, if u're using it for wideband purposes.
Does it represent the upper high frequency ranges well ? good definition ??
What about the low end ?
Do you find it really worth the cash ?
I can attest to xrk's statement.
http://www.diyaudio.com/forums/full-range/221676-mr-bates-your-focused-arrays.html
I do not ever listen to any speaker in the case (Cornu). Technical looks good, the idea is good too. If the casing is counted well, each speaker should sound well.
I have several speakers TB in work (W3-1878 too) - I do not recommend.
Please try some other speakers.
Have a nice day
I use W3 1285SG which i believe have been replaced by W3 1285SP. Its a neo magnet underhung design, and claimed THD is low. I have not seen measures for either mine or your TBs. If the motor system is similar id hope that THD wasnt awful. Id recommend my TBs, but I havent compared specs and sound quality so I have no idea if theyre comparable in quality.
