Does anyone have an designs or ideas for enclosures that use 2 tang band 3 inch drivers?
I was hoping to build 2 tower like speakers with 2 Tang band drivers and maybe a tweeter. I am open to anything that sounds good or is supposed to sound good on paper.
Links, pictures anything is appreciated. I ultimately want to have 2 towers with 2 drivers in each side.
and am just looking for direction on using two drivers. Maybe a transmission line on one driver, a vented enclosure for the other on top of the transmission line? anything low profile and tall...
I would like to use a pair of one of these:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-815
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-813
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-809
or maybe a single one of these:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-817
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-828
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-360
I really liek the look of the Tang Band drivers. Maybe a horn isn't the way to go? if so, do you know of any other designs that would work with the same number of drivers?
