Recent AudioXpress articles say the Tang Band 8" sub has a Qts of around 0.45 to 0.50, as opposed to the manufacturer's number of 0.30. Has anyone here verified that?
If it's true, the driver may be suitable for a closed box subwoofer.
Even if what AX says is true, the high Le will likely result in little bass from a sealed alignment, as GM explained to me on a different question:
http://www.diyaudio.com/forums/showthread.php?postid=311096#post311096
