Chris, let me bounce this off you and please don't think I have issues with nice plywood - other than it cost a lot.
The combination of the flare port(s) and the use of Medex on this build may be a total package, they may be working together. I'm getting very nice low low, natural sounding bass.
That Sahara stranded plyboo is rather nice. Not as much of a looker as Sarah Smart, but as plywoods go, it's not half bad.
or Sarah Shahi
the least flattering / "stirring" photo I could find , but I digress
Oh, I understand about synergy ; congrats on your successful FR builds - it seems it wasn't all that long ago that what I think was your first Fostex build was more than a bit underwhelming
or Sarah Shahi
Nice tan lines.
jeff
or Sarah Shahi
.... the least flattering / "stirring" photo I could find , but I digress
I don't know... naughty librarian?
dave
Nice. I still prefer Sarah Smart though
She was good in Dr. Who.
jeff
I revive this old thread because i have obtained good result with a notch filter. I went on mh-audio.nl - Home for calculate a filter the most narrow as possible. The calcultor gave me : 0.033 mH, 16,2 uF and 17 ohms for 10 dB damping at 7khz. Then, i made a coil by hand , welded it with the caps and made a try. Bad result ! Rather no result at all, the filter was more like a wire. I made an impedance measurment with speaker workshop . The graph showed me that the filter was centered at 5600 Hz . I decreased by steps of 1 uF several times until the notch was centered at 7 kHz with the measured value of 12,9 uF. Then, i made a second try and i figured it out this time, harshness was dissapeared with no bad effect. The high was a bit laid back but i have no put any resistor. I plane to put 15 ohm. I'll post some pictures soon.
Guillaume
Guillaume
Hi !
Unfortunately no because i haven't any acoustic measurement tool but, believe me, the speaker becomes more listenable with this filter . The sound is more relaxed and less colored and without any harshness. The medium frequency seems to be more focused too with a better 3D. http://context.reverso.net/traduction/anglais-francais/I'd+advise+you+to+try
- Full Range
- taming harshness of fostex FF125WK
