[TABLE] Tag appears to be broken
What about code tags (monospacing)
Good suggestion, thanks AllenB.
I'd tried PHP but unlike the example on BB Code , only a single-line box is created.
CODE provides a multi-line box:
Code:
515-8G          A           A +81g              B           B +81g              C           C +81g          D           D +81g
* f(s)=     37.68 Hz    23.55 Hz            37.68 Hz    23.55 Hz            37.68 Hz    23.55 Hz        38.36 Hz    24.9 Hz
* R(e)=     6.36 Ohms   6.354 Ohms          6.179 Ohms  6.125 Ohms          6.128 Ohms  6.164 Ohms      5.877 Ohms  5.834 Ohms
* Z(max)=   118.9 Ohms  86.07 Ohms          130.7 Ohms  89.25 Ohms          123.8 Ohms  87.85 Ohms      119.7 Ohms  71.89 Ohms
* Q(ms)=    5.331       6.019               6.736       7.137               6.302       6.894           6.517       6.122
* Q(es)=    0.3012      0.4798              0.3343      0.5258              0.3283      0.5202          0.3364      0.5406
* Q(ts)=    0.2851      0.4443              0.3185      0.4897              0.312       0.4837          0.3199      0.4968
* V(as)=
* L(e)=     1.365 mH    1.287 mH            1.23 mH     1.18 mH             1.258 mH    1.248 mH        1.178 mH    1.093 mH
* n(0)=
* SPL=
* M(ms)=
* C(ms)=
* BL= 0
* K(r)=     0.04771     0.05257             0.04849     0.05123             0.04182     0.04456         0.04073     0.04622
* X(r)=     0.5487      0.5396              0.5395      0.534               0.5598      0.5547          0.5548      0.543
* K(i)=     0.009589    0.009553            0.007891    0.00753             0.0112      0.01161         0.008797    0.008206
* X(i)=     0.705       0.7053              0.715       0.7188              0.6925      0.6897          0.7         0.7063
Is there a way to widen the textbox?
I think not, that the format is set by the vbulliten configuration.
The table tag doesn't exist in vBulletin, it's inserted by the Wiki software and last I recall asking the author if it can be removed from the main forums and he said no, but that was a long time ago.
So, currently there is no table functionality in the forum.
The good news is that XenForo 2.1 just announced they will have table support via BBcode as well as a WYSIWYG table tool in the editor itself, which is where we will be soon:
XF 2.1 - Font Awesome 5, Editor button management, Markdown support and more! | XenForo community
