thats great to know, thanks.That IC is a little 2 watt into 8 ohm power amp IC. No reason you couldn't use it in a small low power guitar amp. You'd need some sort of preamp circuit.
I'm looking to build the amp out of parts I can find in old electronics. I want to buy as little as possible for it, that's why I am trying it with this specific chip.
do you know of a specific preamp setup that would work, or will any one do ?
(sorry im new to all this )
WHERE did you find one?Hi guys, I am trying to build my own guitar amp, i am taking a complete shot in the dark. Will a TAA 611 B12 chip work ? if so, can anyone please send me in some sort of direction with this ?
It sure brings back memories !!!!
AFAIK it was the *first* full self contained "Chipamp" available , WAY back then (early 70´s) and I remember using it as a prank: I installed one inside a very cheesy Bass Guitar, together with a 9V battery, and claimed that Bass Guitar had such a powerful Pickup that it could straight drive a speaker cabinet ... without an amplifier that is
Took bets which I always won, since plugging it into any speaker produced quite usable sound
Again from memory: you don´t really need a preamp, I remember building the datasheet application and driving it straight from Bass pickup.
1W RMS from a 9V supply, I wouldn´t try any higher for safety.
That said, a modern LM386 costs less than a buck, so ..... I´d consider the Ruby suggested above or even a "Smokey" type amp ... just an LM386 and 2 capacitors
PS: I used the round metal can type.
Hi JMFahey, I found it in an old Barlow Wadley Radio that i got at a garage sale. Do you perhaps still remember how you made yours work ? I know i can always buy a pre setup LM386 board, but im keeping that as a fall back plan, got to keep life interesting with a bit of a challenge, you now.
The Barlow Wadley XCR-30 is a VERY interesting radio and should not be cut-up without further research. One is eBay listed now for $550.
https://www.staff.science.uu.nl/~tel00101/FotoAlbum/RadioCorner/Articles/Barlow30.htm
It is trivial to turn a radio (NOT hot-chassis!!) into an amplifier. Cut the wire to the top of the Volume control. Feed your signal here and the bottom of the Vol pot.
No big deal, I followed exactly the datasheet suggested exampleHi JMFahey, I found it in an old Barlow Wadley Radio that i got at a garage sale. Do you perhaps still remember how you made yours work ? I know i can always buy a pre setup LM386 board, but im keeping that as a fall back plan, got to keep life interesting with a bit of a challenge, you now.
For a single unit, it won´t compensate to custom design a PCB, draw and etch it, etc. , plus troubleshooting it, knowing you will never use that PCB design again, so build it on perfboard and just use it as you wish.
it was quite a fascinating radio to look through. Normaly i wouldnt have cut it up, but i found it in non working order for about equivalent to 1.5 dollars. it had some water damage and years of abuse, so i was not about to lass up the opportunity.
- Live Sound
- Instruments and Amps
- TAA 611 B12 Guitar amp ?
