t10001bd RF
I don't think the board colors are indicative of the year model. The board number is what you need to post. I've attached a photo from a red board. Is it the same as yours? MMBT3904 and MMBT3906.
You can use a different style thermistor but you need to know the value. On the diagram, there are two thermistors on the MEHSA strips and a third one elsewhere. The 3rd one has a different pulldown resistor value so the thermistors on the MEHSA insulators may not be the same as the standard 10k thermistors Rockford uses. Contact Rockford to get the value (not on the diagram) or measure the other MEHSA mounted thermistor in the amp (would require breaking the connection to the rest of the protection circuit). The thermistor must be at room temperature to measure its value.
