T/S Wire Compensation with LIMP (and other software)
Using my Kelvin micro-ohmeter which which I believe bypasses contact resistance in it's measurements, I measured a 16 gauge 312 cm wire (loopback) at .096 ohms (pretty close to what would be expected). Measuring with Limp as a loop back, it came to .51 ohms; presumptively due to contact resistance inclusion of .414 ohms. So, in setting the Cable Compensation Resistance in LIMP, I am wondering if I should include the contact resistance or not as contact resistance will exist in any design?
I have designed many systems with outcomes that I have been pretty pleased with but I never really thought about this before.
Thanks Allen.
Yes, the meter was zero'd before measurement, but since it measures with a 10 mAmp signal and then converts back to ohms using the Kelvin technique, I believe it bypasses the contact resistance in the alligator clips attached to the cable. I wonder about putting a short wire into the clip of the wire and see if that simulates the contact resistance. I realize that the difference is not likely to significantly impact the ultimate design, but it is fun to experiment. Thanks.
