T-amp battery power with charger
Ex-Moderator R.I.P.
Joined 2005
Hi
Is this 12V switchmode supply with integrated battery charger interesting for the small T-amps
155 A - NETZTEIL MIT INTEG.AKKULADERAD im Conrad Online Shop
As I understand it, this supply will monitor the battery
And if theres a power fall out, it will activate the battery
It could be on 24/7
And if you want optimal quality, all you need is to switch off the power, and it runs on battery
Is this correct :confused:
