What are the symptoms of overstuffing a well braced cabinet?
Given that the stuffing still allows free movement of the drivers.
Loss of bass.
Increase in even order harmonic distortion.
In combination, an ill-defined "stuffy" sounding bass.
This is good news! I'll remove the eggcrate stuffing from most of the interior of my Kit 281's tonite, and only stuff them with the recommended amount.
Hopefully, this will improve the bass/midbass.
Thanks for the reply!
I'd recommend measuring the impedance before and after, just to see if you've hit the target Q that you're after.
Sadly, I have no actual equipment for measuring anything, except for a radioshack SPL meter for sound level calibration...
Perhaps this can help
http://www.epanorama.net/documents/audio/speaker_impedance.html
http://sound.westhost.com/tsp.htm
It has instructions and doesnt require any special hardware to do it
drfrink24 said:What are the symptoms of overstuffing a well braced cabinet?
Id sound like id god a code in the nodes.
Tore out all of the eggcrate. I'm not going to make any judgement until I listen to them for a while.
Just make sure you don't go too far in the other direction; at least having the walls lined is a good idea. Then you can vary the amount to hit the target response- or please your ear.
I used the exact abount of polyfill that the plans called for. 6 oz behind each woofer, and, 12 oz in the bottom chamber.
I do it the following way - first I line the walls with thin layer of damping material, if its a closed enclosure I add damping until it I get desired amount of bass and lower frequency extension - in general if you want more deeper lower bass add more stuffing and if more punchier/fast bass add less stuffing, in a vented eclosure you generally dont need any stuffing(you have to damp the walls and brace them though) because the sound is more dependant on port tuning than stuffing, although stuffing increases virtual volume and you can extend the responce a bit, but be careful - as box volume increases port tuning shifts lower and you get a bump on the responce graph resulting in a boomy/one note box.
- Symptoms of Overstuffing enclosures?
