Symmetric tracking lab PSU
Joined 2003
Hi.
I've been thinking about building a small dual PSU.
I'm looking for the following qualities:
- Tracking: neg rail will follow pos rail
- +/- 0-20V, 0-1A
- Current-limiting with a single pot to set both pos and neg rail.
- voltages shall track even when current-limit is active
- No (overly) temperature-sensitive components in voltage or current-reg.
I don't need:
- super-precise current-limit, but I would like it to be stable over time and temperature
- Super low noise and very precise voltage reg.
Inspiration was this:
Paul's DIY electronics blog: Tuning a 0..30V DC 0..3A PSU DIY kit
Based on those ideas, I have played with the idea below:
V1 and V6 are two X-former windings with smoothing (not ideal sim, but ok).
V11 sets current-limit. should be a pot.
V2 sets voltage.
V4, V5, V7 and V8 are voltages needed for the opamps.
U2 and U3 is the current-sensors (voltage-drop over R9 and R8 relative to gnd
U5 inverts the current-ref for the pos rail.
U4 tracks the pos rail.
V3 and V9 is used to simulate step-response and such.
What do you think? Is the idea valid? can the current-regulators work?
Hi. Yes the voltage-tracking is found in many schematics on the web. I don't claim to be first on that part.
I cannot find any simple tracking regulators with variable current limiting that limits both pos- and neg-supply with a single pot.
TroelsM
TroelsM
Not sure about simple, but the HP 6114A can be wired in master-slave configuration. Using two 6114A you can get a very very very precise tracking setup.
Sent from my LGLS992 using Tapatalk
Hi.
- +/- 0-20V, 0-1A
I don't need:
It looks promessing but I you need two separate windings on the trafo and two rectifiers.
If you like experimenting I have another circuit, just an idea, never tryed it.
The noname C's are perhaps nessesairy to came down the comparators ??
Have fun,
Mona
Hi Ketje. That circuit looks a bit like an old Elektor-schematic from my collection (attached, hope it's OK with copyrights).
I don't see how your version works. Do you think that the comparators will work linearly? - or will they just cut voltage completely when activated?
Also not sure how the voltage regulation will work.
Looks very interesting though.
Yes indeed, it looks a bit like my proposal.The LM317 is used directely to regulate the voltage from its ohne 1,25volt reference and the LM337 via an op-amp.
I regulate both sides with an op-amp (comparator= op-amp with open collector out), the reference is 10V on the Vpotm derived from the 7815.
The output from the op-amp goes from approx.-10...+10V for 0...20V out thanks to the 1k5 drop (has a constant current 1.25V/220Ω)
Elektor has two current sensor circuits coupled mechanically (tandem potm).
By inverting one side one can use a single (adj.)treshold voltage.The 100Ω potm gives 0..1V for 0...1A on 1Ω.(A bit better would be the output of another op-amp giving 0-1V)
Too much current pulls the voltage on the Vpotm down until current becomes acceptable.
Mona
Hi Ketje. I've been looking a bit more and I think your schematic makes more sense now 🙂
I'm still not sure that a comparator is the best choice for a linear circuit, but maybe it will work.
Have you simulated it?
Troels
Simulated ? no I don't like that stuff (too old ?)
There is something wrong with the schematic :guilty:
It looks nice symetric but the output of a comparator isn't.The 1k5 from the LM317 is pulled down by the open collecor but the 1k5 on the LM337 side must be pulled UP ! An op-amp pulls both sides but here we need a emitter follower between.
Using real op-amps not comp's is another sollution but then the current limit need diodes like in Elektors schematic, you can't connect two ouputs together like with O.C. outputs.
Mona
