Hello,
I made an INA217-based portable mic preamp powered by a 9V battery using a rail-splitter (TLE2426). It works and sounds well. The only thing missing now is phantom power.
The 9V battery solution is great and I’d like to keep it that way. So I made a boost converter (using a LT8330) that seems promising and delivers low noise 36V from the 9V battery (which will be enough for my purposes).
Now, my problem is that I can’t figure out how to integrate that boost converter regarding the different ground potentials. Please see the attached schematic, there’s
- mic in ground & line out ground
- boost-converter ground (which equals to INA’s V- pin)
- virtual ground for the INA
And obviously I can’t simply connect virtual ground with boost-converter ground.
So in short, is there a way to make this work?
Thanks!
Thanks!
