Swordfishy/ASPEN FETZILLA power amp
Hugh,
Thanks for the explanation. I am aware of the nature of balanced signal feed as I have worked with pro audio gear. However I was unsure of the specifics of running a pair of amps in bridged configuration and as such I didn't know if it was a good idea for the Fetzilla. Thanks for pointing out what the effects would be.
PS. let me know if you and Laurie are heading down to safety beach anytime. I'm still keen on the V-Sonics, but have to clear space and save money before jumping in.
Tani.
Originally Posted by AKSA in the thread jfet-input-mosfet-vas-lateral-output-perfect.
Yes, you should drop approx 200mV across this resistor.
Quite by chance, I discovered this about 15 years ago working on a cascoded VAS, I was amazed, but could never explain it.
Hugh
Hi Sir
Sorry to bother you.
You seem to read this thread more often, so here is my question.
You wrote Cascoded VAS and 200mV drop across a resistor in that VAS.
You also wrote that you was amazed, that's interesting.
Can you say more, any drawings?
Thanx
Paul
No drawings; very simple.
Imagine a npn transistor, with its collector connected to the emitter of a cascoding npn transistor above.
Input taken to the base of the bottom npn, output from the collector of the upper npn.
Upper npn device has base held at a constant reference voltage; this defines a cascode of course.
Simply place a resistor between collector of lower npn transistor and emitter of upper transistor.
The resistor should drop 200mV for what ever current is chosen.
This is Poufou's 'magic resistor'.
Hugh
Mike,
This was 15 years ago, hell, I'm unable to remember where I put my car keys half an hour ago, so a bit of an ask........
Broadly, I noticed better resolution, more ambient details, and somehow a more vivid soundstage, greater sense of space, ALL OTHER THINGS BEING EQUAL.
After a bit of simple math, I realised that what might be happening here was that we were linearising the re of the cascoding transistor. As you are aware, the Zout of a common emitter device is very, very different to the Zin of an EF, so, if the re were linearised by a resistor with a bridging ratio, then things might improve......
And so it was. Take some figures. If VAS and its cascode run at 6.5mA, then Zin of the cascode emitter is 4R (26/Ie). This corresponds to re, of course. If we interpose a resistor and drop 200mV across it, then the value becomes 200/Ie, or 7.7 times the value of Zin of the EF. This is 31R, npv of 33R. 7.7 is suspiciously close to the accepted engineering bridging ratio of 10.
It helps both with impedance transfer from collector to emitter and linearises the input impedance of the EF, drowning it in a constant value. There appears to be no penalty for this, since voltage drop is trivial and hardly affects rail efficiency.
Hugh
Thanks for the info Hugh.
If you look at current mirrors operating with large signals, you'll see that the nonlinear Re of the transistors causes a derivative spike in the capacitive currents of the transistors, at the negative peak when the falling conductance causes a fast risetime across the B-E junction. This is even worse for advanced current mirrors such as the Wilson and so on. So it makes sense linearizing Re is a good idea.
But I don't understand this "bridging ratio" you talk about. I did a Google search and found nothing (whoah...). Can you please tell me what this means?
Also it should be mentioned that thermal drift and generation is an instantaneous mechanism in the silicon die. So by modifying the transistor's thermal profile you are actually affecting it's immediate response and transfer curve. I don't know to what degree though.
Hi Kean,
From wikipaedia:
When the output (output impedance) Zout of a device (the source, ZS in illustration) is connected to the input (input impedance) Zin of another device (the load, ZL in the illustration), it is a bridging connection if the second device does not appreciably load the previous device.
Essentially no power is transferred. The second device is sensitive to the output voltage of the first device, and this is maximized when loading is minimized. All good line level audio connections are bridging, to ensure the high fidelity transfer of a voltage signal from one device in the chain to the next. If the bridging criterion is not satisfied, there may be distortion, altered frequency response or both.
A connection is commonly said to be bridged if the load impedance is at least ten times the source impedance.
So there you have it...... ten times is the magic number!
Hugh
Not far away - one set of GB2 fetzillas waiting for the final couple of caps. Had some tricky bits with the fuse holders and the end diode bridges whos legs seemed too big for the PCB holes. Nothing worthwhile comes without challenges however, nothing 5 minutes with a dremel didn't sort out. I went for a pretty standard build with the Auricaps, was going to try some Mundorf supreme silver/gold and some V-caps TFTF I have but both were too big to not cause issues. I'm trialling a set of Atohm GT1.0's here at the moment and they are stunning with both my Plinius amps and a recent chip amp build - keen to see how Fetzilla steps up. Give me another week and I'll be posting some listening sessions. - AJ
Thanks for the explanation AKSA. Now what if we could use diodes creatively to implement a log-law (or square law? not sure which one is right) Vce so that the dissipation would be perfectly flat, instead of monotonic with a canceled fundamental.
Well maybe it's a job for the square-law class A guys, I'll bet Ed Stuart could throw something interesting together.
I just got done re-fitting my Fetzilla with the proper parts! Ah, after all this time... I will check it over and if everything seems fine, set it on fire. (destroyed a prototype of my own a week ago, degen resistors on fire!)
She's alive - all assembled - tested fine - only had time to listen to one song as I was running out the door sounded stupendous straight up. I'll post a review and some pics later. Many thanks to Hugh and the designers for an awesome piece of kit. - AJ
