switching power supply failure
sdoom said:
If the only problem was the transformer core #2 could I use the old one and rewire it? There is a "big" edge missing but this core is still complete.
Is this core a toroid? What are the measurements of the core? For a toroid, what is the inside and outside diameter, and the height or thickness? You can get a new core to replace the bad one, I think. What is the name and model number of the amp? Maybe the core part number can be found online. If not we can design this from scratch and choose a core that should work. Probably the Mag Inc. P or F core material or the other core manufacturer that makes the 3C8 or 3C85 will work. Also, the primary inductance measurement on the good transformer will help. What are the values of the R and C on the TL494 for setting the oscillator frequency?
Also measure the depth and length of the "big" edge missing from your existing core. Having a chunk of ferrite core missing will make the core act like a step gapped core. In some applications it would be desirable.
@ mwh-eng
Hi again 🙂 Well I´m still sitting here and drawing the schematics. I was in school today what actually was a complete waste of time today! I would have finished the schematics already , but well.
I will make pictures of everything and post them together with the schematics. The broken core had the following measurements.
outside diameter: 36mm
inside diameter : 22mm
height : 19mm
The spare core I used has the same basic measurements and the same windings and wire thickness as the broken one. Would it really effect the TL494 that much? I mean I haven´t put a load on that thing yet. Like I said, I was realy surprised that with only 4 Fets it was running, maybe I should try that again to see if that is still so or if I really have a broken part somewhere.
The regulator is a Motorola TL494CN . CT is 0.001 and RT is 27kOhm . That should be an oscillator frequency from around 40kHz if I am right (taken from a spec-sheet from Texas Instruments)
Well I ´ll continue drawing 😱)
Based on what I can see, I would have expected a little more copper for a dual 450 Watt amp.
Even though you said it worked fine without all the Mosfets in the circuit, maybe you should check all the output capacitors for proper value and possible leakage (resistive).
Did you make measurements on the PWM without the Mosfets or transformer in the circuit? You are probably still waiting on an Oscope to use.
I tested the caps on the output side of the transformer with a good capacity tester and they are fine. Also the caps on the input side had been good. I assume the use of the IRZF48N caused too much ripple current and I somehow don´t belive the guy that sold the new caps to me that they really can be used for switching purposes. A friend of mine told me to re-install the IRFZ48N again as their values are better than the IRFZ44N. Also he said I should replace the 100 Ohm resistors to 47 Ohms to make sure the FET are switching fast enough and I should use "orange" low ESR caps with 63V . What I´m afraid off is that if I make too many changes at once the whole thing won´t turn on or instantly burn or something. As "eva" mentioned I probably have already a huge difference with the cores.
the 450W are considered max musik power 🙂 Tonight I found a guy that actually has schematics for this amp. No kiddin, now as I am almost finished drawing this guy comes up and says " hey, I have the schematics"...
He also has a spec sheet for the amp that says 2x220W RMS @ 4 Ohms or 1x 500 W RMS @ 4Ohms and I think those values should be realistic.
On the picture above you can see the upper transformer (lightly brighter core and darker wire) is transformer No. 2 , the transformer I have replaced. This core comes from a 240W RMS amplifier and has exactly the same windings as the broken original.
I will finish the schematics soon and upload them.
Thx again
Steph
