switching power supply.. can't get -24v?
Now I get -24v and +24 to the pcb but no sound.. gah... i wonder how i bridge the input of rca?
Somewhere in the input stage of the amplifier there are connections for +IN and -IN. So connect the RCA inner and outer conductors to those, and to nothing else.
I am not familiar with that amplifier but from a schematic I found:
http://www.diyaudio.com/forums/pass-labs/111197-aleph-j-schematic.html#post1341101
it looks like you should NOT connect the RCA jacks to the chassis, or to ground, or to anything except the +IN and -IN points in the circuit (since the circuit has a differential input and -IN is separated from ground). So if that's true then you need isolated (insulated) jacks.
Thanks -- I will try this too! All I get a is a little thump when I turn it on
can you confirm any other voltage from tis schm (especially across R8):
