Switchable bias for the A75?
I am using Mr. Pass's A75 design for the front end of an amp I'm buiding. The output stage will be much scaled down, with maybe half the output devices and a lower standing bias current. Even still, it would be nice to have the bias switchable for a "standby" or non-critical listening mode.
The simplest way might be to just use a toggle to switch a resistor in parrallel with R80. However that means running wires right past the power Xfrmr. Could that induce hum?
The next simplest might be to have a small signal relay right at the pc board to switch in a parrallel resistor. But in my experience small relays eventually fail.
Does anyone have a superior way to do this...perhaps using one of my leftover mosfets as an fet switch?
Thanks for any recommendations.
Since I haven't even built the enclosure yet, it will be quite awhile before I can try. If you already have a working amp, it should be fairly simple. Connect a voltmeter across a source resistor to monitor bias current. Connect a 50K pot, set for maximum, across R80. Slowly decrease the pot untill you reach a bias current approx. 2/3 of normal. Remove the pot, measure it's resistance, and select a fixed resistor of the closest value to use with a toggle switch.
The output mosfets should still be in their linear region as long as you give them >100ma idle current each. And the temperature reduction should be significant.
