switch noise
I am wiring up a Rega (Premotec) motor using a 0.22uF 240v cap and 8K resistor.
It works very well but I get a click through the system when I turn the SPST switch on. I think I should be fitting a cap across the switch or a MOV across the live and neutral. I'm not sure which or the correct values.
Can someone help?
Thanks,
Kffern
Try 0.01 mfd over the switch but use a suitably rated cap.
I think the reason Rega do not fit one may be that using just the SPST with a cap across it allows may allow a little current flow through the motor etc even in off position.
Linn, on their basic supply, used caps on the switch but they used a DPST for live and neutral.
Thanks Tubenut,
I should have known as my Lenco has a 0.0039 uF cap across the spst switch. Finding such a low value is difficult but I can get a 0.01uf X2 cap quite cheaply. It's actually for a Luxman A522 which I converted to a Rega motor with bearing/subplatter.
Regards,
Kffern
