Switch for jumpers
Hello,
I am unable to locate a switch that does what I need.
I have an input card for a DAC that can be chosen between USB, coax, and fibre inputs. These inputs can only be changed by manually changing the jumpers. Which can be aggravating when changing sources often and quickly (PC(USB) to transport etc…).
So, before I finalise other design issues I would like to decide of a way changing the jumpers by switch from outside the eventual DAC.
If any of you know a way to effectively switch between three pairs of jumpers pleas let me know.
I would like to start the design of the case and must accommodate the switch somewhere but I first must decide the switch to use and implement for this project.
Thanks in advance for your suggestions.
MV
