Hello All,
Does anyone have a guide to calculating equivalent T/S parameters for modeling DVC drivers?
Some datasheets annoyingly only list the parameters for one coil...
Looking for something like the following:
Parameter 1 Voicecoil ParConfig SerConfig
BL 1 2 2
Re 1 0.5 2
Le 1 0.5 2
Vas 1 ? ?
etc...
any help much appreciated!
cheers,
Mike
BL 1 2 2
Re 1 0.5 2
Le 1 0.5 2
Vas 1 ? ?
etc...
cheers,
Mike
I think the norm for DVC driver specs is for both voice coils in parallel. So if you only see a single set of specs it would be safe to assume it is for parallel voice coils. You can usually tell by the Re value given.
hmmm.... are you sure? check out this pdf and tell me what you think... seems weird that they'd specifially show 2x Re and nothing such on all other specs...
Rockford RFR2212 DVC
thanks!
mike
thanks!
mike
2 x 4 ohms just means both VCs are nominally 4 ohms. Anyway, below the specs it clearly states that the VCs were wired in parallel (nom. 2 ohm) for T/S measurements.
Anyway, here's what you asked for: http://www.subwoofer-builder.com/driver-conversions.htm
GM
GM
My bad ... 😛
thanks! though that chart is not quite right either - voltage sensitivity with series config is NOT the same as with one coil...
makes one wonder about accuracy of the rest.
hm, might actually have to sit down and do this myself... 😉
cheers,
m
madstamm said:thanks! though that chart is not quite right either - voltage sensitivity with series config is NOT the same as with one coil...
Are you sure? 😀
madstamm said:makes one wonder about accuracy of the rest.
shortsighted...
eheheheee... so i suppose this thread is a good example of how to make a fool of oneself ... my grade-school teachers always said i was unusually prone to thoughtless error 😉
my reasoning neglected the additional EM force generated by the coil, excuse me.
thanks.. now after thoughtfully checking your pdf, i think its fair to say that the coils in parallel should have an Le of 1mH instead of 2mH, correct?
cheers,
Humili-mike
parameters of your RF woofer in various connection configurations.
cheers,
Humili-mike
- Subwoofers
- SVC to DVC conversion
