Suspect Faston connector
I am working on my first amp build (a M2 clone) and at this point I'm wiring up the power supply. I began connecting the transformer to the rectifiers today and found that the Faston 250 connectors were pretty loose. They're made by TE Connectivity. For comparison, I tried one of the Faston 205 connectors used on the power switch, and it was quite snug - it took a big effort to get it back off. I tried squashing one of the female Faston 250 connectors with pliers, and I got a snugger fit (no surprise there). I'm wondering if tampering with the connector likely weakened to metal to the point where I'm asking for trouble. I'm also wondering if another brand of female connector will work better?
These connectors must be used as intended, with both parts made by the same manufacturer,
and were intended to fit together. Otherwise, it's pretty much a crap shoot.
Fitting one on something like a generic rectifier block is undefined, and the results are unpredictable.
Soldering is much better in that case.
Reactions: GM and NareshBrd
Arcing contact = big trouble.
Use solder for connections which are supposed to be permanent, or occasionally opened.
Power switch, yes, but use good quality higher rated than needed connectors, male and female from same maker when needed.
Reactions: GM
