I have noticed, since joining this forum a few months ago, that certain people profess a very negative opinion of surface-mount parts. I wonder why this is. These people seem to think that SMD parts are to be looked down upon as inferior to leaded parts. I find this extremely weird.
Take the case of SMD resistors. Several people on this board have recommended against SMD resistors. I have never seen an actual reason given. I think this is bogus, because SMD resistors have all the apparent advantages:
I frankly don't see what resistors with axial leads have going for them. The newest SMD resistors are better in every way, except for power handling. But I think SMD is definitely the right choice for attenuators, terminators, filters, current sources, and low-power circuitry of all kinds.
- Manufactured on advanced processes
- Small
- Low noise
- Low inductance
- Great temperature coefficient of resistance
Wait until you step on an AD797
You don't know you've even dropped an SMT device, at least with through-hole you can attempt to straighten out the pins. I just ordered a batch of SMT devices this afternoon.
I use both. SMT can help keep your sanity since you don't have to drill gazillion holes on 0.100 centers.
Re: Wait until you step on an AD797
Amen.jackinnj said:I use both. SMT can help keep your sanity since you don't have to drill gazillion holes on 0.100 centers.
- Small
- Low noise
- Low inductance
I frankly don't see what resistors with axial leads have going for them. The newest SMD resistors are better in every way, except for power handling. But I think SMD is definitely the right choice for attenuators, terminators, filters, current sources, and low-power circuitry of all kinds. [/B]
It all is true except for one thing: how do they sound?
Personally I never even bothered to check them out (SMD), maybe I should though? Then, I wouldn't be able to built circuits like this.
Most SMD resistors are magnetic. They do not have lower noise and TC and they are very difficult to store/find as components. Advanced manufacturing processes can mean higher profits only.
SMD capacitors have poorer dielectrics than audiophile pp or ps ones. They are excellent for decoupling.
- Small
- Low noise
- Low inductance
I don't have an answer to quality of smd's (resistors or capacitors), but as a DIY or repair center you're confronted with:
1. little things that are harder to solder
2. measuring on smd's is harder (without making bad contacts or even destructive smoking signals)
3. availability is poor
4. bad solderings poorly tracable
5. value readings poor to non available
6. if you found the bad smd unsoldering is harder and require hot air devices with special mouth for each different size IC.
This is typical for our society: ? don't work? trow away and buy new! It's cheaper....
This is NOT compatible with my DIY point of view.
Imaging making test-pcb's with 40 % or more non-recyclable material.
Worked for Siemens during my vacation some 20 years ago when smd made it's first steps. Haha, walking between the ultra-sonic bath to remove soldering flux and test-bank and soldering-iron.
Good soldering-pasta and mask-allignement were problems at those days, guess that improved, but repair is hard, very hard.
In many cases you HAVE TO take whatever they charge you for a new board, you lose a lot of 'independence' that way.
In many ways I more like a Harley with poorer reliability, but I can fix it myself, instead of that flashy jap made of a few thousand non-refurbishable parts.
For SMD caps, the situation is easy. Most SMD caps are ceramic, if film caps are available, they are Mylar (polyester). I haven't come across a polypropylene or polystyrene SMD cap yet.
For resistors, one things is obvious: due to their smaller size, there can be more thermal distortion, but I'd only worry about this for applications where the peak load is a seizable percentage of rated wattage, i.e. feedback resistor in power amp.
The other point is the resistive film. It used to be true that if you bought 1% parts, they were automatically metal film (aka thin film). I'd say that those are pretty much beyond doubt.
Now thick film SMD parts are becoming available with tolerances of 1 and even 0.5%. Problem is, they usually don't tell you what the thick film is. I suppose it could be carbon with some sort of binder. Then there are metal oxide parts like Welwyn WCR, which are made of ruthenium oxide. I have no idea how this compares sonically to NiCr thin film. Some like Phicomp for their PRC111 thick film resistors will only talk about resistive paste, leaving much to the user's imagination. Others, like Meggitt for their CR series will only talk about metal glaze, whatever that is.
I won't comment on megnetic properties...
Eric
Eric
capslock said:For SMD caps, the situation is easy. Most SMD caps are ceramic, if film caps are available, they are Mylar (polyester). I haven't come across a polypropylene or polystyrene SMD cap yet.
I know at least one plastic material but I have temporarly forgot it what is was called. Poly-something with lots of "e"'s.
SMD
Pros:
Small
Good HF performance
Cheap
Easy to get
Easy to pick with a machine
Cons:
Small! Can be hard to solder by hand and also be stressed by heat
Maybe negative properties due to it's small size
Fact
Most of our signal sources (through the whole chain) consists of SMD, (ADC, DAC etc).
I prefer to hold a low profile in this debate because I don't know at all the pros and cons when we talk the sound quality.
I suspect that many people have strong feelings in this matter but most of the negative parts comes from: Don't know anything, can't be good! Don't strangle me for this
Pros:
Small
Good HF performance
Cheap
Easy to get
Cons:
Fact
Just use two solering irons! One works sometimes also. It's hard to burn a SMD component.
Sorry, that was a typo. I meant PPS film, a plastic. Corneil-Dubiler makes the PPS SMT caps I am using; I'd provide a link but I can't seem to get to Mouser. Digikey sells the radial Panasonic ECH-S series, PPS, and according to Harry decent sounding.what is PSP and who makes them?
SMT (De)soldering
100 % agreed!
These SMT thingies were made and intended for machine insertion; NOT for hand soldering.
Yes repair? Repair business is almost dead here.
Buy a new one! Soldering my asynchronous reclocker with MC74VHC74 (SMT!) makes me feel making a spy beetle for the CIA.
My old eyeballs are already popping out even with +3.5 dioptrie glasses!lieven said:I don't have an answer to quality of smd's (resistors or capacitors), but as a DIY or repair center you're confronted with:
100 % agreed!
- Design & Build
- Parts
- Surface mount components poorly regarded
