I have tried surface mount polar caps and my experience with them was not very good. The flimsy little flaps are too fragile and broke off very easily. And they are really too small for hand soldering.
Please tell us what you experience with them. What is the best way to solder them?
Chris
Chris
Are you talking like chip capacitors/resistors? Tin the pads first then place the cap/resistor/chip on the pad. Apply heat to the pad/device and when the solder heats up, the device will "sink" into the pad.
Same trick works for SMD ICs too.
Danny
Danny
i do the toaster oven method -- now probably on my 20th project -- I use a ultrafine tweezer to apply the solder paste -- I have a loupe which, when reversed, magnifies beautifully -- then carefully place the resistors, caps and IC's onto the pads -- of course it helps if you don't drink a lot of coffee.
they take about 2 1/2 to 3 minutes in my special purpose toaster oven - the board will start to fry if you go any longer. obviously, since there are lead fumes involved you don't want to use the toaster oven for any purpose dealing with food.
quite frankly, smt's make it a lot easier to work and the precision of the parts is excellent -- typical matching of resistors on the same reel is usually around 0.1% to 0.5% for resistors -- as if you are making your own filters or differential amplifiers -- are a boon. further, smt opamps, voltage regulators, gate-drivers even the high quality items, seem to be much less expensive and more plentiful on EBay.
Stocker said:what sort of temperature do you use in the oven? I guess it would depend on the solder.
425 F -- or so the setting says on the dial
i've only turned one board to "goo"
The "toaster oven" method is´nt really right for smd soldering, for reflow soldering You need an extremely tight control of heat curve: preheating to activate flux in paste- reflow- rapid cooling.
Precision in chipresistors is good but it is still lousy resistors, You can find metalfilm resistors in melfpackages but nothing close to the quality of even the most comon through hole metal film resitors. SMD/SMT is all about producing high volume cheaply.
SMD semiconductors are as good as throug hole types, but filmcapacitors, for instance, are rotten and seldom survive soldering. Drill holes, if You´re not into making cellular phones
hello,
I want to know how to tell the anode from the cathode for a surface mount eleclytic cap....
I just recieves a bunch of surface mount sanyo os con. I don't understand the marking on them. It's my first time to use them.
If i use my DMM to test its voltage for both ends, I probably can see which one is the cathode. In case that the caps are too old, this method could be indeterministic. Just give me a hint!
CC
CC
contaxchen said:hello,
I want to know how to tell the anode from the cathode for a surface mount eleclytic cap....![]()
If i use my DMM to test its voltage for both ends, I probably can see which one is the cathode. In case that the caps are too old, this method could be indeterministic. Just give me a hint!![]()
CC
There should be a marking of a darkened BAR on the top of the cap to indicate the negative side of the leg at the bottom.
Hope this help.
Chris
HELLO,
Darkened bar? There is a darked side on the top of the caps.... But it gives postive voltage...
What should I do?😕
I think the SMD caps follow the same tradition as conventional ones, but... most of my caps' darked side shows they are anode...
I will just follow what you said.
lhchen
What should I do?😕
lhchen
contaxchen said:
What should I do?😕
Just connect two of them to PS. One cap with dark bar on positive, one cap with dark bar on negative. The one that explodes wasn't connected properly😉 You might put them in some container to avoid any risk.
On tantalum caps dark bar means +
Why don't you look in the datasheet?
Normally the plastic foot has two cut corners = plus
some sort of stripe at the can = negative
Let me also point out that SMD parts are made for machine soldering.
Speaking of drilling holes unless it's for cell phones... I just read an article in a trade magazine discussing relative merits of bonding wire to terminals on the ICs that are stacked FOUR and FIVE tall inside cell phones
anyhow- On some of our PCBs here at work, the surface mount caps have a stripe on one side that is oriented toward a "+" printed on the PCB.
HTH
HTH
HTH [/B]
That is a tantal cap, electrolytics are always marked on negative side, some oscon types marked with + and -.
hello,
It's useless to tear them apart.... I have checked out the structure diagram. The anode is almost symmetric to its cathode. really!
Also, I don't think it gonna blow up if you reverse the positive and it negative. At most, the wrong positioning shorten the cpas life.
That's it.
CC
yes, but for sanyo OScon, you can pull its twe legs straight and solder the cap on PCB. 😎 Their quality seems better than the ones with soldering lugs. I am surprised by it superb metal finish. Nice sense of touching.Let me also point out that SMD parts are made for machine soldering.
That's it.
CC
OK!!
The marked side is the cathode! This is the final conclusion after reviewing several SMD caps manufaturer's website.
C.C.
C.C.
ingvar ahlberg said:The "toaster oven" method is´nt really right for smd soldering, for reflow soldering You need an extremely tight control of heat curve: preheating to activate flux in paste- reflow- rapid cooling.
Well, it might not be "right" but it works, saves a lot of time and real estate. It's much easier to remove smd parts, and it's easier to prototype.
Originally posted by ingvar ahlberg The "toaster oven" method is´nt really right for smd soldering
For SMD rework at work we use a hot-air heat gun at about 400°C with special flux. This method makes out beautiful shiny melted tin. Just place the parts into the paste and look the melting tin. Remove the hot air if the tin is melten completely. You can solder part by part with this method.
You can also solder SMD parts per hand - 0,2mm pitch is possible - although i got an hurting red eye after 500 pins 😀 .
Greetings Ralphono
I also use the hot air soldering equipment. comes useful for shrink tubing too. 😀
I only use hot air for resistors, IC's, transistors, ceramic caps. I always think electros and tants hate high temps.
- Design & Build
- Parts
- Surface mount capacitors
