Support for Botic Linux driver
bern: it seems that the source package was not properly cleaned before packaging. please try following:
Code:
cd /usr/src/linux-headers-4.0.0-botic5
rm -f ./scripts/genksyms/genksyms ./scripts/selinux/genheaders/genheaders ./scripts/selinux/mdp/mdp ./scripts/kallsyms ./scripts/sortextable ./scripts/mod/mk_elfconfig ./scripts/mod/modpost ./scripts/kconfig/mconf ./scripts/kconfig/conf ./scripts/unifdef ./scripts/dtc/dtc ./scripts/conmakehash
make -k scripts
# some errors will be printed by previous command, ignore them
Then you can build mt7601u without errors 🙂
Code:
cd mt7601u
make -C /lib/modules/`uname -r`/build M=$PWD
make -C /lib/modules/`uname -r`/build M=$PWD modules_install
bern: try this... it works for me also with Wifi dongle 🙂
Code:
apt-get install gcc-4.7
cd mt7601u
make -C /lib/modules/`uname -r`/build M=$PWD CC=gcc-4.7
cp mt7601u.ko /lib/modules/$(uname -r)/
depmod -a
modprobe mt7601u
Thank you miero🙂
New module build with gcc-4.7 was successful. However I suspect that not all from old/prevoius build was cleared. When I plug usb wifi dongle I see:
Code:
root@botic:~#
Message from syslogd@botic at Sep  8 14:43:05 ...
 kernel:[   85.931762] Internal error: Oops: 5 [#1] PREEMPT THUMB2
 kernel:[   86.031474] Process systemd-udevd (pid: 1231, stack limit = 0xdd4bc210)
 kernel:[   86.038491] Stack: (0xdd4bde78 to 0xdd4be000)
 kernel:[   86.043114] de60:                                                       bf9ef2a8 00007fff
 kernel:[   86.051796] de80: c007cb6d de57e500 c091d00c 00000000 b6f8cd50 e09b1a5c bf9ef41c bf9ef2a8
 kernel:[   86.060476] dea0: 00000000 c09a5700 000000d2 de57e500 00000000 00000000 00000000 00000000
 kernel:[   86.069157] dec0: 00000000 00000000 00000000 00000000 00000000 00000000 6e72656b 00006c65
 kernel:[   86.077847] dee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
 kernel:[   86.086527] df00: 00000000 00000000 00000000 00000000 00000000 e2620bb4 20000033 0000a6b3
 kernel:[   86.095206] df20: b67546b3 00000000 b6f8cd50 e09bc6b3 dd4bc000 00000000 00000000 c007f525
 kernel:[   86.103884] df40: 00000000 b673a000 e09a2000 0001a6b3 e09b12b4 e09b10a3 e09b9784 0000c424
 kernel:[   86.112564] df60: 0000ecf4 bf9eed10 0000000d 00000000 00000031 00000032 00000026 0000002a
 kernel:[   86.121244] df80: 0000000f 00000000 7224d5f0 00000000 004352d8 0042f840 00000080 c000d9c4
 kernel:[   86.129925] dfa0: dd4bc000 c000d821 00000000 004352d8 b673a000 0001a6b3 b6f8cd50 00000002
 kernel:[   86.138606] dfc0: 00000000 004352d8 0042f840 00000080 00000000 b6f8cd50 0001a6b3 00000000
 kernel:[   86.147291] dfe0: 00020000 bee2e95c b6f86b07 b6eee264 60000010 b673a000 ffffffff 00007fff
 kernel:[   86.172806] Code: f1a3 0508 429a d00c (696b) 4632
Also when i want to see loaded modules and type: lsmod
nothing appears in the putty....
Mayby I need more powerfull power supply for BBB+WIFI dongle? Currently, temporarily I use 1A USB charger...
bern: it seems it is not cleared well, you have to execute "make clean" in the mt7601u directory first
After some fight 😉 and pluging wifi dongle to BBB I get this:
Code:
root@botic:/opt/mt7601u# lsmod
Module                  Size  Used by
mt7601u                70087  0
mac80211              469789  1 mt7601u
cfg80211              397238  2 mac80211,mt7601u
usb_f_acm               7018  1
u_serial               10877  1 usb_f_acm
usb_f_ecm               9489  1
g_multi                 5497  0
usb_f_mass_storage     42586  2 g_multi
usb_f_rndis            22434  2 g_multi
u_ether                11978  3 usb_f_ecm,usb_f_rndis,g_multi
libcomposite           43347  5 usb_f_acm,usb_f_ecm,usb_f_rndis,g_multi,usb_f_mass_storage
nfsd                  211005  2
binfmt_misc             8262  1
omap_aes               13075  0
omap_sham              19186  0
evdev                   8454  1
root@botic:/opt/mt7601u# iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
usb0      no wireless extensions.
It seems like new modules have been loaded but system did not recognize new wifi interface..
And now it is possible that you do not have enough power for this. You can check last lines of dmesg command for some USB errors.
Miero should I do something with /lib/firmware/mt7601u.bin (move to other directory or something):scratch1:
Code:
[  300.652801] cfg80211: Calling CRDA to update world regulatory domain
[  312.346289] usbcore: registered new interface driver mt7601u
[  731.962516] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_bcon (99, VALID), retry #1, port1 00000104
[  732.403780] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[  732.908114] usb 1-1: New USB device found, idVendor=148f, idProduct=7601
[  732.908136] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  733.023791] usb 1-1: reset high-speed USB device number 2 using musb-hdrc
[  733.164322] mt7601u 1-1:1.0: ASIC revision: 76010001 MAC revision: 76010500
[  733.167761] mt7601u 1-1:1.0: Direct firmware load for mt7601u.bin failed with error -2
[  733.168110] mt7601u: probe of 1-1:1.0 failed with error -2
root@botic:~#
yes, there were instructions on driver page you should follow... 🙂
Code:
wget https://github.com/porjo/mt7601/raw/master/src/mcu/bin/MT7601.bin
mv MT7601.bin /lib/firmware/mt7601u.bin
Yep. I downloaded improper firmware (vendor instead of modified) version.
After firmware replacement wlan0 interface is available 😎
So far so good.
However I've found out that mt7601 module is not permanent installed and after rebooting Botic (with wifi dongle pluged in) does not booting normally (I cannot log in using putty as I used to).
I have to remove wifi dongle, reboot and reinstall the mt7601 module to see wlan0 interface. I tried to use wicd-curses to set up wifi connection to my router. Unfortunately BBB not recognise any wifi network.
See below what I'm doing and please let me know what I could improve.
Code:
root@botic:~# cd /opt/mt7601u
root@botic:/opt/mt7601u# make clean
make -C /lib/modules/`uname -r`/build M=$PWD clean
make[1]: Entering directory `/lib/modules/4.0.0-botic5/build'
  CLEAN   /opt/mt7601u/.tmp_versions
  CLEAN   /opt/mt7601u/Module.symvers
make[1]: Leaving directory `/lib/modules/4.0.0-botic5/build'
root@botic:/opt/mt7601u# make -C /lib/modules/`uname -r`/build M=$PWD CC=gcc-4.7
make: Entering directory `/lib/modules/4.0.0-botic5/build'
make[1]: Warning: File `include/config/auto.conf' has modification time 4.8e+08 s in the future
  LD      /opt/mt7601u/built-in.o
  CC [M]  /opt/mt7601u/usb.o
  CC [M]  /opt/mt7601u/init.o
  CC [M]  /opt/mt7601u/main.o
  CC [M]  /opt/mt7601u/mcu.o
  CC [M]  /opt/mt7601u/trace.o
  CC [M]  /opt/mt7601u/dma.o
  CC [M]  /opt/mt7601u/core.o
  CC [M]  /opt/mt7601u/eeprom.o
  CC [M]  /opt/mt7601u/phy.o
  CC [M]  /opt/mt7601u/mac.o
  CC [M]  /opt/mt7601u/util.o
  CC [M]  /opt/mt7601u/debugfs.o
  CC [M]  /opt/mt7601u/tx.o
  LD [M]  /opt/mt7601u/mt7601u.o
make[1]: warning:  Clock skew detected.  Your build may be incomplete.
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /opt/mt7601u/mt7601u.mod.o
  LD [M]  /opt/mt7601u/mt7601u.ko
make: Leaving directory `/lib/modules/4.0.0-botic5/build'
root@botic:/opt/mt7601u# cp mt7601u.ko /lib/modules/$(uname -r)/
root@botic:/opt/mt7601u# modprobe mac80211
root@botic:/opt/mt7601u# insmod ./mt7601u.ko
Module                  Size  Used by
mt7601u                70087  0
usb_f_acm               7018  1
usb_f_ecm               9489  1
g_multi                 5497  0
nfsd                  211005  2
binfmt_misc             8262  1
omap_aes               13075  0
omap_sham              19186  0
evdev                   8454  1
root@botic:/opt/mt7601u# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 54:4a:16:bf:a9:7c
          inet addr:192.168.0.13  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::564a:16ff:febf:a97c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:405 errors:0 dropped:0 overruns:0 frame:0
          TX packets:434 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:38907 (37.9 KiB)  TX bytes:61403 (59.9 KiB)
          Interrupt:170
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:3594 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3594 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:384835 (375.8 KiB)  TX bytes:384835 (375.8 KiB)
usb0      Link encap:Ethernet  HWaddr 5a:bc:90:91:9e:f4
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 00:0c:43:01:0a:94
root@botic:/opt/mt7601u#dmesg
[  285.980009] cfg80211: Calling CRDA to update world regulatory domain
[  296.127857] usbcore: registered new interface driver mt7601u
[  346.549073] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_bcon (99, VALID), retry #1, port1 00000104
[  346.982522] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[  347.486668] usb 1-1: New USB device found, idVendor=148f, idProduct=7601
[  347.486686] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  347.602442] usb 1-1: reset high-speed USB device number 2 using musb-hdrc
[  347.742960] mt7601u 1-1:1.0: ASIC revision: 76010001 MAC revision: 76010500
[  347.751318] mt7601u 1-1:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[  348.176393] mt7601u 1-1:1.0: EEPROM ver:08 fae:00
[  348.400433] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
So far so good.
After activation hostname DHCP in the wicd-curses for the short time I saw list of wifi networks (including mine). I guess I could not connect for longer because I lost connection due to insufficient current. Driver will be probably working when I replace PSU from 1A to 2A.
But what to do to load mac80211 and mt7601u modules automatically/dynamically?
