Just moved to the Bronx. Unfortunately, in the move one of the channels in my 41hz amp 5 is now dead, though I think its just a loose connection. Probably need some new wiring, and may want a terminal strip er whatever they call those things you solder to a pcb and then screw down on a wire. If anyone has suggestions for a supply shop in the NYC area, I'd be thrilled.
Thanks!
Thanks!
