Supplier for Philips CDM12x/VAM12xx Rubber Shock Absorber (Suspension) wanted
All CD loaders for Philips/Marantz CD Players, where is inside the CDM12x/VAM12xx mechanism, e. g. that one from the URL
http://www.hifisounds.co.uk/manuals/Marantz-CD17AKM cd.pdf
uses the same kind of absorbers as you will find in the attached image.
This parts are available in black, white so as
transparent and milky color as to see in the picture.
Who is the manufacturer?
Thank you for your advice
for more pics check out this German thread:
Reparatur Lasereinheit/Laufwerk CD 17 & Modifikationen - Phono - Restaurierung und Selbstbau - Analog-Forum
BTW - about
http://www.diyaudio.com/forums/digital-source/124622-suspension-rubber-cdm12-x.html
I find several helpful advices concerning the assembly but I don't find the name of the manufacturer, where Philips these purchases.
BTW - about
No informations?
It looks like parts from a gasket profile similar like that one from
http://www.easterngasket.com/
available by the meter.
scroll down and open the Image 5.2.4.3.3.2 - 4:
(Hydrotite gasket profile)
tiefbassuebertr:
Did you ever locate a source for this item? I desperately need a set.
Regards,
Scott
Regards,
Scott
no. the only possibility is to order used models like CD713, CD723, CD753, CD751 to get this parts.tiefbassuebertr:
Regards,
Scott
check out also this:
Reparatur Lasereinheit/Laufwerk CD 17 & Modifikationen - Seite 2 - Phono - Restaurierung und Selbstbau - Analog-Forum
