Nice topolgi.
Drivers and outputs are BJT's but shown as FETs.
You forgot the feedback.
1 ohm is a pretty high value for emitter resistors in a 50W class A amp. (Edit: and I see now they are in the collectors - is that the way to do it?)
Are the tempco of the 33ohm NTC suitable to fit the outputs BJTs PTC?
But Stee - keep on going.
Haven't you drawn the output transistors the wrong way. I guess they should be common collector, not common emitter, or am I missing something?
Are you copying the Jung buffer input of that circuit or are you coying the darlington commomemitter driverstage?
It looks more like a Sziklai, and in that case I am not sure you can put the drivers emitters on the opposite outputs collector.
If you simulated it or build it and it works, then I am just gonna say - super - tell us how it sounds.
Otherwise check the sziklai from other amps, and see how they do.
Re: see the original
Look at the direction of the transistors to the left in this schematic. I think this is how it should be.
Since the whole schematic can't be seen, we don't really know what happens outside this fragment. It's not a Sziklai.Stee said:directly from japan![]()
Re: yes you are right
This output is drawn as positive feedback, the more V across the .47 Ohm resistors the harder the output is driven. Magic smoke?
Stee said:i have taked inspiration from Accurphase design 😉
so in the original schematic
the output bipolar was in reversal mode
but my idea is use output resistor as negative feedback
Re: Re: see the original
But you are right - it is none of those - it's a Stee
I meant that Stee's output looks like a cross between a Jung buffer and a sziklai.nelsonvandal said:
It's not a Sziklai.
Stee: We love new revolutionary designs.
We are very much looking forward, to hear if your prototype works, and how it sounds.
Can the amp use 2SA1943/2SC5200 output devices? I have lots of them....
No caps anywhere?
Any other drivers possible?
Sorry to ask....
No caps anywhere?
Sorry to ask....
yes you can
http://www.ampslab.com/trans_2sa1837.htm
finally an investigator who loves working group
please don't forget NTC glued on power transistor
use +/- 25V with big dissipator 😉
- SuperOPA
