Sundown Salt 500.4 power supply driver transistors
Anyone have a cross reference for these? Saw original power supply devices were 3205. Can I use the same mosfet with 47 ohm gate resistors?
All 4 of these circuits are copy and paste. Use one of the others for a reference.
The diode passes voltage from the 494 to the gate resistors when the output from pins 9/10 is high (near 12v). Sometimes an NPN transistor is used. Either will work. This is what they chose to use.
The PNP transistor is used to pull the gate drive voltage back to ground when pins 9/10 go back to ground.
