Sundown prototype
Not sure what kind of amp this is but a guy told me it was a sundown prototype..
I dont believe the amp is powering up since the power light is not lit when power is applied..
Heres what i get on the 494
Pin 1:0.92
Pin 2:VOLTAGE IS PULSING
PIN 3:0.06
PIN 4:0.06
PIN 5:1.44
PIN 6:3.59
PIN 7:0
PIN 8:0.71
PIN 9:0.10
PIN 10:0.10
PIN 11:0.71
PIN 12:13.71
PIN 13:4.95
PIN 14:4.95
PIN 15:4.18
PIN 16:0.01
Heres some pics of the amp
Any ideas on where to start checking since the amp is not powering up?
When tracing the gate leg of the power supply fets back they connect to Leg 1 of a couple of C1023 transistors then go thru a couple resistors then to pin 9 of the 494.. I only get 0.10 volts on pin 9 of the 494 ..
Im going thru the power supply right now and pretty much rebuilding it due to further inspection some has jumped traces ect..
I cam across a C102 transistor..
In diode check this is what i get does it appear to be ok or defective ?
Legs 1-2:OL
Legs 1-3:OL
Legs 2-3:OL
Probes reversed
Legs 1-2:1.034
Legs 1-3:OL
Legs 2-3:OL
